Answer Quadratic Implicit Function: Horizontal/Vertical Tangent Line
  • Thread starter Thread starter ada0713
    Function Implicit
ada0713
a. Find dy/dx given that x^{2}=y^{2}-4x=7y=15
b. under what conditions on x and/or y is the tangent line to this curve horizontal? vertical?
2. The attempt at a solution
I did solve the first question by simply using implicit fuction.
2x+2y*y'-4+ty*y'=0
y'=\frac{4-2x}{9y}
above is the answer that i ended up with
but I am kinda stuck with the second question
if the tangent line is horizonat i guess the slope has to be zero
so i just set \frac{4-2x}{9y}=0 and
i ended up with x=2
but i don't know what to do with "vertical" part and
i'm not sure if i got the "horizonal" part either.
for a that's right, just when you wrote out the question you forgot some +'s and put = instead.
yes horizontal tangent is when the derivative =0. so x=2 is current for that.
vertical tangent occurs when the the derivative = +-infinity.
and if you have a fraction when does it = infinity?
If the question is supposed to be x²+y²-4x+7y = 15 then I believe that your answer for y' is incorrect.
Note that your original equation is that of a circle which has been shifted. To write it in standard form, (x-a)²+(y-b)²=c² you can complete the square (I'm getting to a nice geometrical result, just hang on :D)
(x²-4x+4) -4 + (y²+7y + 49/4) - 49/4 = 15
(x-2)² + (y+7/2)² = 15 +4 + 49/4
(x-2)² + (y+7/2)² = [sqrt(125)/2]²
So your original equation is a circle of radius [sqrt(125)/2], centered at (2,-7/2). From this you should gather that there are 2 points that have a horizontal tangent, and two points that have a vertical one.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
