Implicit second order partial derivative
MeMoses
Given that the surface (x**5)(y**2)+(y**5)(z**3)+(z**3)(x**2)+4xyz=7 has the equation z=f(x,y) in a neighbourhood of the point (1,1,1) with f(x,y) differentiable, find the derivatives
(∂**2f)/(∂x**2) at (1,1)
I already solved for ∂f/∂x and ∂f/∂y for the first part of the problem implicitly, but how to I solve for the second order derivative? I've tried ∂f/∂x * ∂/dx to no avail. All of my other attempts were really just hunches which turned up nothing as well. Thanks for any help.
What did you get for ∂f/∂x and ∂f/∂y ?
at point (1,1) I got -11/10 for both ∂f/∂x and ∂f/∂y
What did you get for ∂f/∂x and ∂f/∂y in terms of x, y, and f in the neighborhood of (1, 1, 1), before you evaluated them at (1, 1, 1) ?
for ∂f/∂x i got -(5x**4*y**2+2z**3*x+4yz)/(3y**5*z**2+3z**2*x**2+4xy)
and
for ∂f/∂y i got -(2x**5*y+5y**4*z**3+4xz)/(3y**5*z**2+3z**2*x**2+4xy)
both of which were found using ∂f/∂x = -(∂/dx)/(∂/∂z)
I got the same for ∂f/∂x . I didn't do ∂f/∂y.
But I did it a different way.
At any rate take the partial w.r.t x of the following:
\displaystyle \left( \frac{\partial f}{\partial x}\right) \left(3y^5(f(x,y))^2+3(f(x,y))^2x^2+4xy\right)=-\left(5x^4y^2+2(f(x,y))^3x+4yf(x,y)\right)​
Notice that I replaced z with f(x,y). After you've taken the derivative, change f(x,y) back to z, if you like.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
