Importance of Low Resistance per Unit Length in Electrical Cables
Low resistance per unit length in electrical cables is crucial for efficient operation, especially with long connections to appliances. It allows for a larger current to flow, which is necessary for appliances to function properly. However, higher currents can lead to increased power dissipation, reducing efficiency and safety. The resistance of the cable affects the overall performance, as lower resistance minimizes energy loss as heat. Ultimately, maintaining low resistance is essential for both effective power delivery and minimizing energy waste.
Kushal
Some electrical appliances are used with long cables to connect to them to the electrical supply. State and explain 2 reasons why these cables should have a low resistance per unit length.
well for the long cables, a low resistance per unit length would mean a low resistance for the cable itself. a larger current will flow.
i cannot see any advantage in that. rather the cables will be less safe with a larger current. the power dissipated, I2R, will be larger, hence less efficient.
so i don't know...
well for the long cables, a low resistance per unit length would mean a low resistance for the cable itself. a larger current will flow …
Hi Kushal! :smile:
No … you've completely ignored the resistance of the appliance
it is (mostly) that resistance which determines the current, I.
So the current is more-or-less fixed by the appliance.
So the effect of the resistance of the wire is … ? :smile:
yeah you're right, i completely ignored that. a small current might not be able to operate the appliance.
errmm i still can't find the second reason... a hint would be great...lol
thnks
thnks
It looks like you were on to the second drawback in your first try.
EDIT: Nevermind, got resistance confused with impedance.
Anyway, yes you were close. Think of the Thevenin equivalence circuit.
You guys have completely forgot that the higher the voltage of the current moving through the mains power the less energy that is lost through heat and for that to work the resistance must be low.
