Importance of Wattage Difference
  • Thread starter Thread starter Megasundato
    Difference Wattage
Using 1/2 watt resistors instead of the specified 1/4 watt resistors in a robot circuit should not cause any performance issues, as the higher wattage rating indicates they can handle more power without burning out. The main concern arises only if a lower wattage resistor is used in place of a higher wattage one, which could lead to overheating and damage. The larger 1/2 watt resistors may occupy more space on the circuit board, so it's important to ensure they fit properly without interfering with other components. Overall, the build will likely be more robust with the higher wattage resistors. As long as there is enough space and proper fit, the current configuration should work effectively.
Megasundato
Hello, me again with another rookie question. lol
I've almost completed all of the circuits for my robot; however, I noticed that the parts list required all of my resistors to be 1/4 watts, but the majority of resistors I've applied are 1/2 watts.
I'm kind of pressed for time right now so I'm probably not going to start over unless it's of absolute necessity to do so. I just need to ask a few questions.
What would be the effects of the wattage difference? I'm ok if it's something trivial such as faster or slower movements, but I definitely won't want to damage the BS2 stamp.
What would be the effects of connecting a 1/4 resistor and a 1/2 resistor?
As I said, I don't mind if it's just trivial problems, but if it might damage it or if it would just not work, I would need to change it.
If it helps, here is the link to the schematics I'm using
http://www.reconnsworld.com/bs2sonar.html
Thanks for your help
If the design requires 1/4 watt resistors, and you use 1/2 watt resistors, everything should work the same, and your build should actually be more robust in temperature extremes.
The watt rating mainly serves to define how much power the resistor can dissipate before it burns up. Your only problem would be if the design asks for a higher watt resistor and you put a lower watt in its place, then the resistor is at risk to burning up.
Performance shouldn't make a difference if all else is equal.
They will take up a little more space on your circuit board than 1/4 watt resistors. Check to make sure there is enough space on your circuit board for them. Will they fit in the holes? Are there other components nearby that they may interfere with or that will interfere with them?
Great. thanks for the help.
no, I got a lot of spare room. thanks though.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
