Magnification at a Different Distance from Mirror?
The discussion revolves around calculating magnification when a person moves further from a mirror. Initially, a magnification of 1.50 is achieved at a distance of 12.0 cm, with a focal length of 0.36 m. When the person moves to a distance of 3.7 times the focal length, the magnification becomes -0.62, indicating an inverted image. The conversation highlights confusion regarding the signs of magnification for real and virtual images, noting that real images are typically inverted while virtual images are upright. Understanding these concepts is crucial for solving the problem accurately.
DaveMann
The focal length between a person and his mirror that produces a magnification of 1.50 when his face is 12.0 cm away is 0.36 m. He then moves to a distance of 3.7 times the focal length away from her mirror. What is the magnification now?
di/do=m
1/f=1/di+1/do
I've been trying to work this out on paper for the last hour. When his distance is 2.6 times the focal length, the magnification is -0.62. I can't figure out why that is though. There seems to be 2 variables.
The images can be real and virtual. One image is upside down, which one? What is the sign of magnification in case of a real image and in case of a virtual image?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
