How is Impulse Related to Momentum?
  • Thread starter Thread starter pirateboy
    Impulse Momentum
Impulse is directly related to momentum, as it represents the change in momentum of an object. The net impulse calculated for the 40kg object over 3 seconds is 39 kg·m/s, indicating the change in momentum. The final momentum is derived by adding the initial momentum (800 kg·m/s) to this change, resulting in a final momentum of 839 kg·m/s. The average net force exerted on the object during this interval is 13 N. The discussion emphasizes the importance of understanding the relationship between impulse and momentum to simplify problem-solving.
pirateboy
I'm a bit confused by this question. If you could help me check my work, that'd be great.
Thanks.
A 40kg object with an initial velocity \vec{v}_0 = (20 \text{m}/\text{s})\hat{i} is accelerated by a varying net force \vec{F}(t)=\left[ \left( 3.0 \text{N}/\text{s}^2\right)t^2 - \left( 4.0 \text{N}/\text{s}^2 \right)t + 10.0\text{N} \right]\hat{i} over a time interval of 3.0 seconds.
a) What is the net implulse (\vec{J}) received by the object using the force equation above.
b) What is the final momentum of the object at the end of the time interval?
c) What is the average net force exerted on the object over the time interval?
\vec{p} = m\vec{v}
\vec{F}_{\text{net}} = \frac{d\vec{p}}{dt}
\vec{J} = \int_{t_i}^{t_f}\vec{F}(t)\,dt
F_{\text{avg}} = \frac{J}{\Delta t}
I had trouble at part b.
a)So \int_{0}^{3.0}\vec{F}(t)\,dt = \left[ \left(t^3 -2.0t^2+10.0t \right)\hat{i} \right]_{0}^{3.0} = 39 \text{kg}\cdot\text{m}/\text{s}
b)This is where I was confused.
Well, since \vec{p} = m\vec{v}, I solved the indefinate integral
\int\vec{F}(t)\,dt = t^3-2t^2+10t + C
And since
\vec{F}_{\text{net}} = \frac{d\vec{p}}{dt} and \vec{p} = m\vec{v}
then
\vec{p}(0) = t^3 - 2.0t^2 + 10.0t + C = m\vec{v}_0 = 800,
so C = 800?
So final momentum is
\vec{p}(3) = (3)^3 -2(3)^2 + 10(3) + 800 = 815 \text{kg}\cdot\text{m}/\text{s}??
c)
F_{\text{avg}} = \frac{39}{3.0-0} = 13\,\text{N}
Welcome to PF, pirateboy.
I don't see why (b) needs to be so complicated.
The impulse is equal to the change in momentum, so your 39 is the change in momentum. Final momentum is 40*20 + 39.
I think you have an adding error in the line where you get 815. I get 839 there.
where did that 15 come from? that's what i get for having a jumbled scratch sheet, i guess.
and wow, i guess 40*20 + 39 does make sense, doesn't it. i guess i just got caught up in making things difficult for myself. thanks!
Most welcome!
