Where is the Point of Suspension to Keep a Suspended Rod Fixed?
  • Thread starter Thread starter AbigailM
    Impulse Rod
AbigailM
For prelim preparation. I've also included a figure of the problem.
A stick of length l is suspended by one end at point P so that it hangs vertically and so that the top end of the stick does not move. A horizontal impulse J is applied perpendicular to the stick a distance a below the point of suspension. In general there will be an opposite impulse J' that must be given at the top of the stick (point P) to keep its point of suspension fixed. Find the distance a such that J'=0.
\tau=r\hspace{1 mm} x\hspace{1 mm} F
\tau=I\alpha
L=T-U
L=\frac{1}{2}I\dot{\theta}^{2} +mg\frac{l}{2}cos\theta
Using Lagrange's Equations
I\alpha=-mg\frac{l}{2}sin\theta
Equating the two equations for torque and setting r=a
I\alpha = aFsin\theta
Equate the last to equations
aFsin\theta=-mg\frac{l}{2}sin\theta
Solving for F
F=-\frac{mgl}{2a}
Therefore J is
J=-\frac{mglt}{2a}
So J' is
J'=\frac{mglt}{2a}
Is this looking correct? Gracias!
I don't think that's right.
you have torque T=Fa since it applied perpendicular.
since it gives an impulse to balance the torque. if torque is zero no impulse. then a=0 is the point you are looking for i assume.
Your langrangian should have the constraint term too coming from the applied force.
You seemingly haven't solved for a, have you? a(J' = 0)?
I'm not up on Lagrangians any more but might look at the classical solution later.
OK, looked at it, seems simple if I did it right.
If you get an answer I'll tell you if it's what I got.
Hint: torques about the c.g. ?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
