In what direction is the scout's position relative to the campsite?
The discussion focuses on a scout's movement and calculations related to his position relative to a campsite. The scout walks 5 km east, then turns left to walk 4.5 km along a circular arc, and finally moves 3 km directly toward the camp. Participants are seeking help with determining the scout's final distance from camp, the direction of his position relative to the campsite, and the ratio of displacement to total distance traveled. Key strategies include using diagrams and understanding circular motion to solve for angles and distances. The conversation highlights the importance of applying geometric principles and kinematic equations in solving these types of problems.
neutron star
Okay, the first one I have no clue how to set up or start, so a hunt would be nice. The second one, I figured out (a) but can''t seem to get (b) or (c) and want to know what I'm doing wrong.
A scout walks 5 km due east from camp, then turns left and walks 4.5 km along the arc of a circle centered at the campsite, and finally walks 3 km directly toward the camp.
(a) How far is the scout from camp at the end of his walk?
___ km
(b) In what direction is the scout's position relative to the campsite?
___ ° (clockwise from north)
(c) What is the ratio of the final magnitude of the displacement to the total distance walked?
___
A particle moves in the xy plane with constant acceleration. At time zero, the particle is at x = 3.0 m, y = 6.0 m, and has velocity v = 1.0 m/s i + 7.0 m/s j. The acceleration is given by the vector a = 9.0 m/s i + -1 m/s j.
What is the velocity vector at t=3.0s
I got (28 m/s) i+ (4 m/s) j
What is the position vector at t=5.0s
What is the magnitude and direction of the position vector
I would start with a diagram!
For the circle part, you know the distance from camp will be the same everywhere on the circle so that part is easy. You can get the angle through figuring out what part of the full circumference is walked, and take that same part of 360 degrees.
