Inclined plane with atypical axes/ Lagrangian
The original poster attempts to solve a problem involving a box on an inclined plane using the Lagrangian approach, while facing challenges due to atypical coordinate axes. The axes are defined such that the x-axis runs horizontally from the high end to the low end of the incline, and the y-axis runs vertically downward.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the necessity of incorporating a constraint equation to ensure motion along the incline. There are questions about the application of rotation matrices and the implications of using different coordinate systems. The original poster expresses confusion regarding the derived accelerations in the x and y directions, questioning the validity of their results.
Some participants have provided guidance on using constraint equations and transformations to analyze the problem. The conversation reflects a mix of interpretations and attempts to reconcile the results obtained through different methods. The original poster acknowledges the influence of constraints on the acceleration in the y direction.
There is an ongoing discussion about the implications of using unconventional axes and the resulting calculations. The original poster has indicated a lack of familiarity with rotation matrices, which may affect their approach to the problem.
david13579
I'm asked to solve the typical intro level box on an inclined plane problem but I need to do it using the lagrangian.
My difficulty with it is that the axis I am required to use are not the typical axes used when solving this using Newtonian mechanics. Instead of the x(or y) axis being along the incline with the other perpendicular to it, the axes here are the x-axis going from the high end of the incline to the low end and the y-axis from the top to the bottom (so x is horizontal facing left and y is vertical facing down)
I am then asked to compare the answer using lagragian to the answer using Newtonian stuff.
http://i.imgur.com/OAosTDI.png
I've tried a billion different ways and always and always end up with the acceleration in the y direction being g(sin(a))^2 and in the x direction g(sina)(cosa).
On one hand it makes no sense since obviously the acceleration in the y direction should be just g but on the other hand it makes sense because if we find the acceleration along the incline it is clearly gsin(a) as doing with a the typical coordinates of x along the incline would show. Then, if the acceleration is gsina along the incline, breaking it into components along the x and y axes would multiply it further by another sina in the y direction and cosa in the x direction which shows the same thing I got using the Lagrangian method.
So I have been going in circles with something that makes sense yet doesn't make sense.
If you use those coordinate axes, you have to add a contraint equation that forces the motion to be along the incline, and use the method of undetermined multipliers. Have you done that?
When you have solved the accelerations in x and y directions, make a transformation to a coordinate system that has been rotated by angle a in the clockwise direction (you know rotation matrices, don't you?) and see whether the accelerations along the new axes are 0 and gsin(a).
Doing the same question with constraints is a separate question so there has to be a way without constraints. The first question is to do it and the second is to do it again using a constraint (which I think should be f(x,y) = y-xtan(theta)=0
And no, I don't know rotation matrices.
Here are 2 of my attempts at it:
without constraints http://i.imgur.com/wQ9RKSA.png
With constraints http://i.imgur.com/7zvNv6w.png
both give me the same result. And like I said before, if I draw on paper and try it as a problem of breaking vectors into components, I get the same answer but then again it also contradicts that if y is vertical then logically only g should be the components and nothing else.
Your answer is correct. The acceleration in y direction is not g because both gravity and the support force of the inclined plane act on the object, not only gravity.
And now, after further thinking I even see that the constraint is what prevents g from being the acceleration in the y direction. mg-λ=mgsin2(a) which would be the force in the y direction with the acceleration I found.
:) Thanks a lot.
  • · Replies 25 ·
  • · Replies 21 ·
