Increment value of equvalent resistance when the resistances are parallel
The discussion focuses on calculating the increment in equivalent resistance (d(R3)) for two resistors (R1 and R2) in parallel. The equivalent resistance is defined as R3 = R1*R2/(R1+R2). The total differential of R3 is expressed as dR3 = (∂R3/∂R1)dR1 + (∂R3/∂R2)dR2. Participants explore the relationship d(R3)/R3 = d(R1)/R1 + d(R2)/R2 + d(R1+R2)/(R1+R2) and seek clarification on its derivation. The conversation emphasizes understanding the mathematical functions involved in resistance calculations.
sudhir1962
R1 & R2 are two resistances in parallel. d(R1) & d(R2) are the incremnet in resistance. If R3 is the equvalent resisitance such that R3=R1*R2/R1+R2, then if d(R3) is increment in equvalent resistance. What is the value of d(R3)/R3.
Hmm, well, if this is anything like I'm seeing it to be, you're dealing with functions:
R_3:\mathbb{R}^2\to\mathbb{R}
So the total differential/change of R_3 would be:
dR_3=\frac{\partial R_3}{\partial R_1} dR_1 + \frac{\partial R_3}{\partial R_2} dR_2
Actually I found it in some place as follows
d(R3)/R3= d(R1)/R1+d(R2)/R2+d(R1+R2)/(R1+R2), please let me know how it is arrived.
