Index/angles of refraction for violot/red light
  • Thread starter Thread starter frozenguy
    Light Refraction
The discussion revolves around calculating the angle of emergence for red light from a prism where violet light exits perpendicularly. Participants discuss the application of Snell's law, particularly focusing on the indices of refraction for violet and red light, noting that the index of refraction for violet light is 2.00% larger than that for red light. The calculations involve determining angles of incidence and refraction at both surfaces of the prism, with specific angles mentioned, such as 50 degrees for incidence on the left surface and 30 degrees for refraction. The conversation highlights the importance of understanding how light disperses within the prism and how to apply the refraction formula effectively. Ultimately, the calculated angle of emergence for red light is approximately 0.997 degrees.
frozenguy
White light is incident onto a 30.0[deg] prism at the 40.0[deg] angle shown in the figure. Violet light emerges perpendicular to the rear face of the prism. The index of refraction of violet light in this glass is 2.00% larger than the index of refraction of red light. At what angle (phi) does red light emerge from the rear face?
on paper
So This is what I was thinking, but not sure if I can use those equations like I did.
Also, if the violet light is refracting perpendicular, that means it was not perpendicular to the right side before it exited/refracted, right?..
Thanks for your help!
You need the refraction formula with the angles in it.
n1*sin(θ1) = n2*sin(θ2)
In the special case where θ2 = 90 degrees, it doesn't matter what the indices are; you can immediately calculate θ1.
Having that θ1 for incidence on the right side, you can work your way around the triangle to get the angle of refraction into the left side, then use the formula again to find the index of refraction for violet light in the glass.
Hey Delphi51 thanks for responding! I really want to get this problem.
So how is θ2=90[deg] (if θ2 is the angle between the violet ray and the normal to the right surface)? I assumed it was 0[deg] to the normal.
And if θ2 was 90deg, sin(θ1)=n2/n1 right? How do the indices not matter?
Oops, sorry. Of course θ2=0. So θ1=0.
What is the angle of incidence for the left-hand surface?
What is the angle of refraction for the left-hand surface (for violet light)?
Its cool, ok so n_{1}=\frac{n_{0}sin\theta_{0}}{sin\theta_{1}}
So n1 is the index of refraction for the prism right?
Is there a standard wavelength for violet light that I'm supposed to use (400nm?) to find the index of refraction? Can I use \frac{\lambda_{2}}{n_{1}}=\frac{\lambda_{1}}{n_{2}} ?
SammyS thanks for responding!
I got 50[deg] for that
I got 30[deg] for that..
When does the light turn into colors? during refraction back into the air or during refraction into the prism?
Ok so I've been doing a little research. Looks like the light disperses inside the prism with their respective angles of refraction, and then again when leaving the prism at another angle of refraction.
Oh. Ok.. So since the violet light is parallel with the base of the triangle, I'm finding nviolet with n0sinθ0=n1sinθ1 on the left side considering θ1 to be 30deg from normal of left surface and θ0 to be 50deg.
The question states nviolet = 1.02nred right? I'm going to work with that..
Did you get the number for the violet index of refraction (from knowing the angles of incidence and refraction for the first surface)? Then you can get the red index and do the refraction at the second surface. You don't need to work with wavelengths at all.
I get 50 deg for my red angle to the norm of the right surface.. Sound right? I'll upload my work..
Can I assume that the index of refraction is 1.0003 in air for red light, violet light, etc?
Entering the glass on the left side:
1*sin(50) = n2*sin(30)
Solve for n2. This is the index of refraction of the prism for violet light.
Then use your nviolet = 1.02*nred to find the index for red light.
Yeah I did that.. Lemme upload it.
here we go..
nvg is nviolet,glass
nrg is nred,glass
the ra is red,air etc.
Goal is to find phi which in this case I labeled θra
I must assume this right? Otherwise the colors would go their own separate ways!
Okay on the 30.7, but not the last step.
You must begin with 30.7 and work your way around the triangle to find the angle of incidence on the right hand surface. It should be very close to zero. And after you run it through the law of refraction, very close to zero coming out of the prism.
Ok I get that.. 90-30.7=59.3
And then that big angle is 180-60=120deg
So 180-59.3-120= 0.7 deg incident to right side?!
Ok so θra=0.997deg=phi
