How Does a Moving Magnet Induce Voltage in a Rectangular Coil?
  • Thread starter Thread starter Sami Lakka
    Induction Magnet
The discussion centers on the equation for voltage induced by a moving magnet over a rectangular coil, expressed as V = L*dI/dt + RI = ωΦ cos(ωt). The participants explore the derivation of this equation, particularly how it relates to magnetic flux and angular frequency. They note that magnetic flux is calculated as the product of area and magnetic field strength, with voltage being the time derivative of this flux. The conversation highlights the connection between angular frequency and the changing magnetic flux that induces voltage, similar to principles used in alternating voltage systems. Understanding these relationships is crucial for applications involving Halbach arrays and magnetic levitation.
Sami Lakka
I read interesting article regarding Halbach arrays and magnetic levitation (see www.lmco.cn/data/assets/9197.pdf[/URL]). In the article (see equation 1) the author states that the voltage generated by moving magnet over rectangular coil is
V= L*dI/dt + RI = [tex]\omega \Phi cos(\omega t)[/tex]
Where [tex] \Phi[/tex] is the peak magnetic flux and [tex] \omega[/tex] is the frequency defined by the wavelength of the Halbach array.
Where does the right side of this equation come from. Is it derivative from sin function containing the omega and phi? How is this equation formed? I'm puzzled..
okay I've seen something similar . So magnetic flux is (area)B*cos(x)
and voltage is the time derivative of magnetic flux . let's say that we are rotating our cross sectional area with an angular frequency so now the flux is changing and we have a voltage . I will call my angular frequency Q so the flux is AB*cos(Qt)
so the time derivative of this will be voltage . This is what they do for alternating voltage.
B= field strength
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
