What is the limit of (e^x-1)/x as x approaches 0?
  • Thread starter Thread starter kidia
The limit of (e^x - 1)/x as x approaches 0 is evaluated using inequalities, showing that it approaches 1 from both sides, thus confirming that lim (e^x - 1)/x = 1 as x approaches 0. For the limit of (x^3 - 1)/(x - 1) as x approaches 1, polynomial division is suggested to simplify the expression. Alternatively, L'Hôpital's rule can be applied if permitted. The discussion emphasizes using the squeeze theorem and rewriting inequalities for clarity. Overall, the methods outlined provide a clear approach to evaluating these limits.
kidia
friends help on this,
Use the ineequalities 1+x<=e^x<=1/1-x for |x|<1 to show that
lim(e^x-1)/x =
x-0+
lim(e^x-1)/x =1
x-0-
and hence deduce that
lim(e^x-1)/x=1
x-0
b) Determine
lim (x^3-1)/(x-1) if it exists.
x-1
Mathematics news on Phys.org
Rewrite your inequalities.
For example:
1+x \leq e^x
is the same as:
1\leq \frac{e^x-1}{x}
Do the same for the other side of the inequality and use the squeeze theorem to evaluate the limit.
As for b), perform polynomial division first.
Or L'Hopital's rule if you're allowed to do so.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
