Inelastic collision of ball and rod - rotation problem
The discussion revolves around solving a problem involving an inelastic collision between a particle and a hinged rod. Participants explore the application of conservation laws, particularly angular momentum, while questioning the necessity of calculating the center of mass (CoM) for the system. It is clarified that while total kinetic energy cannot be conserved, angular momentum can be conserved about the hinge, which simplifies the calculations. The importance of choosing the correct reference point for angular momentum is emphasized, as the CoM is not suitable due to hinge forces. Ultimately, the correct angular velocity is derived as 6mu/(3m+M)L, demonstrating the effectiveness of the discussed approach.
Krushnaraj Pandya
A uniform rod of mass M and length l is hinged at the center. a particle of mass m and speed u sticks after hitting the end of the rod. find the angular velocity of the rod just after collision
Energy conservation-0.5mu^2=0.5(m+M)v^2
Angular momentum conservation about hinge-muL/2=MoI about COM*angular velocity
CoM=m1x1+m2x2/m1+m2
Can we apply energy conservation since the hinge isn't specified to be frictionless?
I'm sure we can conserve angular momentum about hinge though, taking hinge as origin the CoM comes out to be at a distance mL/2(M+m) and moment of Inertia about CoM can be calculated using parallel axis theorem but this gives a lot of complicated terms. Is there a simpler way to solve this question then?
Why do you need to calculate the COM?
The friction at the hinge is not your main problem
What does this tell you about the particle-rod collision?
Its purely inelastic, so we can't conserve total kinetic energy... but we can still write m1v1+m2v2=(m1+m2)v3. so mu=(M+m)v. but using v=Lω/2 gives an incorrect answer
to apply initial angular momentum=Iω. I is about CoM
You did ask
Let me rephrase my question: Do you really need to calculate the COM?
PeroK said:
You did ask
could I write Iω about hinge for the sytem, then add Mv(com)*distance of com (for rod)+ mv*distance of com(for particle) instead? I'd still have to find the CoM though, I don't see any other way
True or false:
The rod has an angular momentum.
The mass has an angular momentum.
The angular momentum of the rod-mass system is the sum of the two, regardless of whether they are stuck together or not?
Also a warning: The CoM is a very bad choice for a reference point here. Due to the forces at the hinge, the angular momentum about the CoM will not be conserved.
PeroK said:
True or false:
True! Oh, how silly of me. That was amazingly simple, I was just overthinking it. I got the correct answer as 6mu/(3m+M)L, Thank you very much :D
Likes PeroK
Ohh, I was under the impression that for a combined system we always need to write I about CoM while using initial AM=Iω. but adding them separately makes a lot of sense as I now discovered
If you want to use conservation of angular momentum, then you need to write down your angular momentum equations relative to a point around which the torque is zero.
ok, I understand- thank you
