Infinite R-chain: Find Resistance Between A and B
  • Thread starter Thread starter Vanessa23
    Infinite
The discussion focuses on calculating the equivalent resistance of an infinite chain of resistors, each with a resistance of 90 Ω, connected between points A and B. The user attempts to simplify the problem by first considering the equivalent resistance of a finite series of three 90 Ω resistors. There is an implication that a pattern may emerge from this simpler case, which could help in determining the resistance of the infinite chain. The goal is to find a single resistor value that matches the resistance of the infinite configuration. Understanding the behavior of series resistors is crucial for solving the problem.
Vanessa23
Consider the infinite chain of resistors shown above and suppose that each resistor in the chain has a resistance of 90 Ω. What is the resistance of a single resistor that could be connected between A and B with the same resistance as that of the infinite chain?
A------R-------R--------R--->
R R R to infinity
B------R-------R--------R--->
This is the best I could do to show the chain of resistors. It is the equivalent of a series of boxes with a resistor on each side.
Lets start off with a somewhat easier example:
What is the equivalent resistance of three 90 ohm resistors in series? 4? 5? Notice a pattern?
