Inflection points using 2nd derivative
  • Thread starter Thread starter Beeorz
    Derivative Points
Beeorz
Find all inflection points,
f(x) = -x^3/2
n/a
f'(x) = -3/2x^-1/2
f''(x) = 3/4x^-3/2
The f''(x) does not exist. I know that doesn't necessarily mean that there isn't any inflection points, but how do I go about finding them? Ususally I just set the 2nd derivate equal to 0 but it doesn't seem to work in this case. When I do set it equal to 0, I get x=0. And when I check points to the left and right of f''(0) the 2nd derivate doesn't change signs. Does that mean there is no inflection points??
I am assuming you meant that f(x) = \frac{-x^3}{2}
But you are correct in saying that f''(x)=0 => x=0 . f(0)=?
Now check the sign of f'(x) at say x=0.1 and at x=-0.1. See if the sign changes.
[You are to check if the sign of the gradient changes which is given by f'(x)]
Judging by his derivatives, he actually means
f(x) = -x^{3/2}
which should have been written as -x^(3/2).
First of all, I don't think your derivatives are correct, check them again.
Yes, I meant f(x) = -x^(3/2)
wish I knew how to use w/e program that you guys are using so that there is less confusion..in looking at my derivative..they seem correct to me
basically -(3/2)x^((3/2)-1) = -(3/2)x^(1/2)...no?
ill check over them again and see
\frac{d}{dx}f(x) = \frac{-3}{2}x^{1/2} is correct, however that is not what you had in your first post.
However there cannot be a point of inflection at x=0 because the domain is only defined from [0,inf) which automatically means that the second derivative cannot change signs at x=0 because it to is only defined on (0,inf)
Ah, I see my mistake.So,
f'(x) = (-3/2)x^(1/2)
f''(x) = (-3/4)x^(-1/2)
(-3/4)x^(-1/2)=0
x=0
Taking test points to the left and right of x=0 yields no sign change, thus there is no inflection point.
Would what I said above be correct to say? We currently solve for inflection points setting the 2nd derivative equal to zero. We then use those zeros and divide the x-axis into intervals. Using a test point within those intervals we determine the sign of f''. If f'' changes sign then there is a inflection point.
Just wanting a confirmation :smile:
You can't 'test' to the left of zero, i.e. negative numbers. As has been pointed out, this function isn't defined for negative x, and you just took a square root of a negative number in your last post as well in the higher derivatives.
