How to Solve the Inhomogeneous Heat Equation for a Cylindrical Rod?
mumaga
inhomogeneuos heat equation!
∂θ/∂t= D∇2θ + K, the mensioned equation is the heat equation for a cylindrical rod , and the requaired is to find the ordinary differential equation for θ(r) .where the radius of the rod is R , and K is constant ( correspond to a constant rate pf heat production)
i use separation of variables to obtain the required for a homogeneous heat equation , but with the constant the method didn't work out.
thanks for your time.
Welcome to PF!
Hi mumaga! Welcome to PF! :smile:
(I assume you mean ∂θ/∂t= C∇2θ + K, where C and K are constants, and θ depends only on t and r.)
See http://en.wikipedia.org/wiki/Heat_equation#Homogeneous_heat_equation :smile:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
