Initial Voltage in an RC circuit with a Current Source and no Voltage Source
The discussion focuses on deriving the expression for the voltage across a capacitor in an RC circuit with a current source and no voltage source. The initial condition is debated, with one participant calculating Vc(0) as 20V based on a 10mA current through a resistor, while another asserts it should be 0V due to the capacitor acting as a short circuit at t<0. Clarification reveals that with the switch closed, the current bypasses the resistor, resulting in no voltage drop across it and thus no initial voltage across the capacitor. The conversation emphasizes understanding the behavior of current in parallel paths and the implications for voltage across circuit components. The resolution highlights the importance of recognizing the capacitor's initial charge state and the role of current flow in determining voltage.
Bassa
[/B]
Derive an expression for vc(t) in the circuit of Figure P4.13 and sketch vc(t) to scale versus. I attached a screen shot of the circuit for this problem.
time.
V = IR
V = V0exp(-t/tau)
[/B]
I am trying to find the initial conditions to this problem. To do this, I have said that at t < 0 the capacitor will act as a short circuit for a dc current. we would then have that the current that is going through the resistor R is 10mA. This would yield to Vc(0) = (.01)(2000) = 20V. When I checked a solution of this problem, they get that Vc(0) = 0V. I am not really sure why that is! Thank you very much for your help!
Bassa said:
[/B]
View attachment 113412 time.
V = IR
V = V0exp(-t/tau)
[/B]
Short circuit means zero resistance. Would the current flow through the resistor, when it can choose a parallel zero-resistance path?
Thanks you for the quick reply! Oh! I I did not think of it this way. My answer would be "No, it would not." That raises another question that might be related to a fundamental piece of information that I don't know. Current would also not flow if there was no change in voltage, which the resistor offers, right?
Yes, no current through the resistor implies zero voltage across it.
But you can think in the point of view of the capacitor. At t=0, there is zero charge on it. The voltage across a capacitor is V=Q/C. So zero charge means zero voltage across the capacitor, and the resistor and capacitor are parallel connected, so V(t)=0 at t=0.
Is your "relevant equation" V = V0exp(-t/tau) correct then?
So, I think that I am misunderstanding the problem. The arrow on the switch in the diagram means that the switch was closed for a long time and then it was opened at t=0s. If this is the case, then would that not mean that the capacitor was charged at t <= 0?
If the switch is closed, it means short-circuit for the current source. Why should the current choose a different path?
I think I am starting to understand where you are coming from. Initially, I thought that current would not go through the parallel piece of wire because there is no voltage drop there, but it would go to the resistor because there there is a voltage drop and the current could flow. I have always thought that current would not go throw a wire that did not have a voltage drop. I think this is where my misunderstanding is coming from.
Moderator's note: Changed the thread title to make it less generic and more specific to the problem being addressed.
Thank you for the note. I changed the title of the thread.
Would the current not choose the path that has a voltage drop, which is the one with the resistor?
Current *causes* a voltage drop when it flows through a resistor. If it's flowing elsewhere, there will be no voltage drop.
How do you know that there is a voltage drop across the resistor? The voltage across a resistor is U=IR. The resistor is not connected to a voltage source, the voltage across it is determined by the current. Zero current, zero voltage.
The branch including the closed switch has zero resistance. So the voltage across the current source is zero. So is the voltage across both the resistor and capacitor.
Likes Bassa
Thank you very much for this explanation! I really appreciate it!
Thank you!
