What is the Instantaneous Rate of Change at X=2 for the Function F(x) = 4/(x-1)?
wearingthin
Find the irc at X=2
F(x) = \frac{4}{x-1}
\stackrel{lim}{h\rightarrow0}\frac{F(a+h)-F(a)}{h}
I end up with \frac{4}{h+h^{2}} or some other form of an h on the bottom. Is there something else i can do to it??
\frac{4}{(2+h)-1} - \frac{4}{2-1}
all over h
is how i set it up originally
and then
\frac{4(1)}{(1+h)1} - \frac{4(1+4)}{1(1+h)}
still all over h
which becomes
\frac{h}{1+h}
all over h
right??
You made the mistake in your third post; that 4 in the very top right should be an h
wearingthin said:
and then
still all over h
First factor out the four so it's easier to work with\frac{\frac{4}{h+1} - \frac{4}{1}*\frac{h + 1}{h + 1}}{h} = \frac{4\left(\frac{1}{h + 1} - \frac{h + 1}{h + 1}\right)}{h}
then see if you can cancel that h in the denominator.
IRC = -4
You're a genius! Thank you
-Matt
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
