Why Does Gauss' Law Imply Integral of Electric Field is Zero?
Harrisonized
Hi everyone. This isn't a homework problem. Rather, I'm trying to understand how the δ term arises from the field of a dipole.
Greiner supplies the following one-line derivation, which is easy to follow I guess, but doesn't make logical sense to me. Specifically, I don't understand how Gauss' law implies that ∫ E dV = 0. Gauss' law says that div(E) = 0, and if you actually do calculate that in spherical coordinates, you'll find that the dipole field indeed has 0 divergence.
E = 2p cos θ /r3 er + p sin θ /r3 eθ
∇·E = 1/r2 ∂/∂r (2p cos θ /r) + 1/(r sin θ) ∂/∂θ (p sin2 θ/r3)
= -2p cos θ /r4 + [1/(r sin θ)] 2p sin θ cos θ/r3
= -2p cos θ /r4 + 2p cos θ /r4= 0
Logically, I wouldn't expect ∫ E dV = 0, because right in the center of two opposite point charges, there should clearly be an electric field pointing in the -z direction. Therefore, the integral over dz should always be nonzero. What am I doing wrong?
https://imagizer.imageshack.us/v2/534x313q90/46/gjlo.png
https://imagizer.imageshack.us/v2/534x85q90/607/0io5.png
Eq. (1.21):
https://imagizer.imageshack.us/v2/534x152q90/855/w4zh.png
https://imagizer.imageshack.us/v2/418x295q90/829/lqdy.png
The Δ actually means ∇2
. Homework Equations Gauss' law (∇·E = 0) The Attempt at a SolutionI believe the answer to this question lies in the fact that Gauss' law is a vector equation, and thus it is being applied to the entire vector field, not just its components. This means that although the integral over dz may be nonzero, these values are cancelled out by the other components of the field. Therefore, the integral over the entire volume is indeed 0.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
