Integral of $\frac{1}{x\sqrt{4x + 1}}$: Solutions and Explanations
  • Thread starter Thread starter PhysicsinCalifornia
    Integration
The integral of $\frac{1}{x\sqrt{4x + 1}}$ can be simplified by substituting $u = \sqrt{4x + 1}$, leading to the transformation of the integral into a more manageable form. The discussion highlights the use of partial fraction decomposition to integrate $\frac{1}{u^2 - 1}$, which can be expressed as a combination of simpler fractions. Participants suggest that the integral is related to the inverse hyperbolic tangent function and recommend using trigonometric substitutions like $u = \sin\theta$ or hyperbolic functions such as $u = \tanh t$. The conversation emphasizes the effectiveness of these methods in finding the antiderivative. Overall, the integral can be approached through various techniques, each yielding valid solutions.
PhysicsinCalifornia
\int \frac{1}{x\sqrt{4x + 1}}dx
I let u= \sqrt{4x+1}, u^2 = 4x+1
So \frac{1}{2}u du = dx
\int \frac{\frac{1}{2}u}{(\frac{u^2-1}{4})*((\sqrt{u})^2)}du
\int \frac{2u}{(u^2 - 1)*(u)} du
\int \frac{2}{u^2 - 1} du
2\int \frac{1}{u^2 -1}du
Can anyone help me anti-differentiate what the integrand is?
Isn't it related to the inverse hyperbolic tangent of u?
Try u=sinθ.
I'd suggest partial fraction decomposition...
Expanding that fractions gives:
\frac{1}<br /> {{u^2 - 1}} = \frac{1}<br /> {{2\left( {u - 1} \right)}} - \frac{1}<br /> {{2\left( {u + 1} \right)}}
Partial fractions work. So does u=tanh t.
