Solving Integral Problem: Stuck?
  • Thread starter Thread starter shadow5449
    Integral
The integral problem involves the expression integral ((sqrt(4-x^2))/x) dx, with a substitution of x = 2sin(theta) leading to dx = 2cos(theta)d(theta). The next steps include rewriting cos^2(theta) using the identity cos^2(theta) = (1+cos(2theta))/2, which simplifies the integral to 2 integral (1+cos(2theta))/sin(theta) d(theta). Further simplification can be achieved by using sin(theta) = 2sin(theta/2)cos(theta/2) and substituting u = sin(theta/2) to streamline the expression. Ultimately, integrating each term separately and reverting to the original variable will yield the final answer, emphasizing the importance of checking the result by differentiation.
shadow5449
I've almost gotten through this one integral problem, but I've seem to have gotten stuck:
i let x = 2sin(theta), and dx = 2cos(theta)d(theta)
sqrt(4-x^2) = 2cos(theta)
integral ((2cos(theta))/(2sin(theta)) * 2cosd(theta)
2 integral cos^2(theta)d(theta)/sin(theta)
That's as far as I got, any suggestions?
Sure, express cos^2(\theta) [/tex] in terms of the sin function, sort of like yo udid earlier. You're on the right track.
It looks like you're on the right track with your substitution of x = 2sin(theta) and dx = 2cos(theta)d(theta). To continue solving this integral, you can use the trigonometric identity cos^2(theta) = (1+cos(2theta))/2. This will allow you to rewrite the integral as:
From here, you can use the trigonometric identity sin(theta) = 2sin(theta/2)cos(theta/2) to simplify the integral further. This will give you:
4 integral (1+cos(2theta))/(2sin(theta/2)cos(theta/2)) d(theta)
Now, you can use the substitution u = sin(theta/2) to simplify the integral even more. This will give you:
4 integral (1+cos(2theta))/(2u) du
From here, you can use the fact that cos(2theta) = 1-2sin^2(theta) to simplify the integral further. This will give you:
4 integral (1+1-2sin^2(theta))/(2u) du
Finally, you can use the substitution v = sin(theta) to solve the integral completely. This will give you:
4 integral (1+1-2v^2)/(2v) dv
Now, you can integrate each term separately and plug back in your original substitution to get the final answer. Remember to check your answer by taking the derivative to see if it matches the original integrand. Keep up the good work and don't get discouraged, solving integrals can be tricky but with practice and patience, you'll get the hang of it!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
