Integratable combination question
  • Thread starter Thread starter snowJT
    Combination
snowJT
Obtain the general solution of 2xydy - 6y^2dy + 8xdx + y^2dx = 0
2. The attempt at a solution
2xydy + y^2dx = 6y^2dy - 8xdx
\intd(xy^2) = \int6y^2dy - 8xdx
xy^2 = \frac{6y^3}{3} - \frac{8x^2}{2}+C
xy^2 = 2y^3 - 4x^2+C
3. Homework Statement
Find the particular solution of the DE that satisfies the condition y = 5 when x = 1
4. The attempt at a solution
(5)^2 = 2(5)^3 - 4+C
25 = 250 - 4+C
C = -221
Does all of this look right to you? I'm not so sure about the last part?
i think it looks good...but i am always wrong about these things...can someone else see if this is correct or not
It's right. Did you really tex all of that up to get someone to check your arithmetic? :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
