Integrate e^-a|x|: Troubleshooting & Solution
  • Thread starter Thread starter dotman
    Integrate
dotman
I'm a little confused with this integral:
\int^\infty_{-\infty}e^{-a|x|}\,dx
Now, I believe the typical way to evaluate this is to say, hey, because of the |x|, this thing is symmetric about the x axis, and so we can instead evaluate:
\int^\infty_{-\infty}e^{-a|x|}\,dx = 2\int^\infty_0e^{-ax}\,dx
= 2[-\dfrac{1}{a}e^{-ax}|^\infty_0] \, \, = \, 2[\dfrac{1}{a}] \, \, = \, \dfrac{2}{a}
which I believe is correct. However, and this is my question, can it be evaluated without using this trick? I ran into trouble, and I'm not sure where I made my mistake, although I suspect it has to do with not really doing anything about the absolute value of x:
= \, \, [-\dfrac{1}{a}e^{-a|x|}|^\infty_{-\infty}]
= \, \, -\dfrac{1}{a}[e^{-a|\infty|} - e^{-a|-\infty|}]
= \, \, -\dfrac{1}{a}[e^{-a\infty} - e^{-a\infty}]
= \, \, -\dfrac{1}{a}[0 - 0] \, = \, 0
And I've gotten nowhere, but I can't tell why, or what mistake I committed (if any).
Thoughts? What am I missing here? Thanks!
the first way is correct it comes form the fact
e^{-a|x|} = e^{-ax},x\geq 0
e^{-a|x|} = e^{ax},x < 0
so the integral becomes
\int^\infty_{-\infty}e^{-a|x|}dx = \int^{0}_{-\infty}e^{ax}dx + \int^{\infty}_{0}e^{-ax}dx
which simplifies to what you gave (use substitution u = -x in first part)
your 2nd interegral is not valid due to the different behaivour of e^{-a|x|} either side of zero
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
