Integrating the Error-function: Using Differentiation under the Integral Sign
  • Thread starter Thread starter Nikitin
    Integral
11 replies · 3K views
Nikitin
If you know
[tex]\int_{-\infty}^{\infty} e^{-\alpha \beta^2} d \beta = \sqrt{\pi / \alpha}[/tex]
Show that
[tex]\int_{-\infty}^{\infty} \beta^2 e^{-\beta^2} d \beta = \sqrt{\pi}/2[/tex]
I have tried integration by parts on the second integral, but to no avail. I just end up with it being equal to zero. What am I to do?
Nikitin said:
If you know
Show that
How did you split the integrand up when you did integration by parts?
Dick said:
You don't really need to do integration by parts. Take the derivative with respect to ##\alpha## of both sides of your first equation. Then set ##\alpha=1##.
This is a very nice trick, and I like it a lot. But it could be Nikitin needs to work on integration by parts.
Yes, probably. It's easy enough to do that way too.
Yeah, I must've done a silly mistake when doing the integration by parts. I set the ## \beta^2 ## term as u, and the ##e^{ -\beta^2} ## term as v'.
Then, (btw, how do I put limits on the left part of a bracket in latex?)
[tex]\int_{-\infty}^{\infty} \beta^2 e^{-\beta^2} d \beta = \left [ \beta^2 \int e^{-\beta^2} d \beta \right ]_{-\infty}^{\infty} - \int_{-\infty}^{\infty} 2 \beta (\int_{-\infty}^{\infty} e^{-\beta^2} d \beta ) d \beta[/tex]
If I try to insert
[tex]\int_{-\infty}^{\infty} e^{-\beta^2} d \beta = \sqrt{\pi}[/tex]
into my integration by parts expression, I will just end up with 0. Can somebody please do it properly so I can find my mistake?
PS: Sorry for late reply. Oh, and thanks for all the help and nice tips :)
I don't want to be a bore (I like your method), but how do you know it's possible to differentiate the term inside the integral first, instead of taking the integral first and then differentiate?
http://en.wikipedia.org/wiki/Leibniz_integral_rule And for your integration by parts, put ##dv=\beta e^{-\beta^2} d\beta##. What does that leave for u?
I don't completely understand why you'd do that?
Is the integration-by-parts expression in post #6 correct? Why can't I just insert ##\int_{-\infty}^{\infty} e^{-\beta^2} d \beta = \sqrt{\pi}## into the expression and solve?
If you are going to set ##dv=e^{\beta^2}d\beta## then v is the INDEFINITE integral of dv. You don't apply the limits till the end. And that expression doesn't have an elementary indefinite integral. Hence my alternate suggestion.
If I try to insert
Re taking the derivative under the integral, note that the integral is with respect to ##\beta##. For purposes of regarding ##\alpha## as the variable to differentiate against, all the ##\beta## stuff is essentially a constant.
Re integration by parts take u(x) = x and v'(x) = x##e^{-\alpha x^2}##. The new integral will pop up looking very like the one you know to be ##\sqrt {\pi /\alpha}##.
Okay, now I fully understand. I didn't think about putting v'(x) = x e^-x^2, as I wasn't aware of
Now everything is clear. Thanks guys!
