Integrating Velocity When in Unit Vector Notation
To find the displacement of a particle given its velocity in unit vector notation, one can integrate the velocity function over the desired time interval. The example provided shows the integration of the velocity vector, resulting in a displacement vector calculated between t=1s and t=3s. It is confirmed that each component of the velocity can be treated separately during integration, allowing for the individual evaluation of each unit vector. The final displacement is obtained by summing the results of these separate integrations. This method is valid and effectively demonstrates how to handle vector integration in physics.
ThomasMagnus
Say for example, a particles velocity was given by the following equation:
\vec{V}(t) = (2t2-4t3)\hat{i} - (6t +3)\hat{j} + 6\hat{k}
If I wanted to find the displacement of the particle between t=1s and t=3s, could I just integrate like this?
\int \vec{V}= (2t3/3 - t^4)\hat{i} - (3t2 +3t)\hat{j} + 6t \hat{k} evaluated between 1.00 and 3.00
= (-63i)-36j + 18k)-(2/3-1)i+(6j)-6k= -63.3i - 30j + 12k.
Is this the correct way to do this?
N/A
N/A
Yep, that's correct.
As for why it's correct, suppose the particle's velocity was just 6i, so the distance is only changing in the i direction so you only integrate in that direction. Then if it's velocity was 6i + 3j, the total displacement is the same as moving the i component, then traveling in the j component separately.
The total displacement is just the vector sum, hence why your integration is correct.
So can you just treat each unit vector separately and integrate and evaluate each individually, then combine them all to find the displacement vector?
Thanks!
Yes, you can.
