Integration. About -ve area and stationary value.
SolCon
Greetings to all. :smile:
Okay, I have 2 simple questions about integration. They are summarized in topic title.
1) This is the figure:
http://usera.ImageCave.com/biosyn/qq.PNG
It shows a curve y=x^2 and the line y=3+2x.
Point A is (3,9) and point B is (-1,1).
We have to calculate the area of the region enclosed between the curve and the line segment AB.
I have used the formula A=\int (y2-y1) dx. Correct me if the formula is wrong. I've used the limits 3 and -1. Now, I have solved this and obtained the answer, but the problem is that the Area I'm getting is coming in negative. The answer to this question is 32/3 which is what I'm getting but only that it is -32/3.
Is this something to do with the figure or have I done something wrong?
2) This is the second part of a question. First part is done. We were asked to show the Volume, V cm^3, was given by:
V=12\pir2-2\pir3.
Okay, now the second part of the question says that Given that r varies, find the stationary value of V.
What I did here is, because the stat.value says that dV/dx = 0, I used:
0(dV/dx)=12\pir2-2\pir3.
0=24\pir-6\pir2.
After this, I don't know what else to do. The answer is coming as 64\pi. But how is this coming?
Any help? ::confused:
Did you use -1 for the lower limit and 3 for the upper limit or did you have them backwards?
V=12\pir2-2\pir3.
What volume? Was this formula given or is it something you calculated?
0=24\pir-6\pir2.
So you would factor it:
6\pi r(4 - r^2) = 0
and r = 2 is the only reasonable value giving a non-zero volume. What volume to you get if r = 2? I'm guessing you may have a sign error in your volume calculation, which you didn't show.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
