Which term should be chosen for u(x) in integration by parts?
The discussion revolves around finding the indefinite integral of the function ∫(x^2/(2+x^3)) dx. The correct integration by parts formula is confirmed, but participants suggest that integration by parts may not be necessary for this problem. Instead, a substitution of u = x^3 is recommended to simplify the integral to a standard form. Additionally, it's noted that selecting the term whose derivative approaches zero quickly, such as x^2, can aid in the integration process. Ultimately, the consensus is that simpler methods exist for solving this integral without resorting to integration by parts.
zanazzi78
ok i`m really struggling with the concept.
I've been asked to find the indefinite integral of;
\int \frac{x^2}{(2+ x^3)} dx
so before i beg for the answer could someone confirm that i`ve got the right rule to solve this;
\int u(x) v'(x) = [ u(x) v(x)] - \int v(x) u'(x)
if this is right would you mind giving a suggestion to what u(x) to use?
p.s. i may have to edit this if latex doesn`t come out right I've been having trouble with it and only jointed the forum a few day's ago!
Yes, that is the correct formula (it's surely in your textbook), but I don't see any good reason for using integration by parts. That's a fairly standard anti-derivative: look up "arctangent".
I`ve just edited it. Now it`s integration by parts! see I`m getting all flustered
Actually, you still don't need integration by parts. Substituting u = x^3 will simplify it to a standard form.
Anyways, since differentiation is in some sense the inverse operation to integration, every differentiation rule yields an integration rule. I'm sure you remember the product rule:
\frac{d}{dx}(f(x) g(x)) = f^\prime (x) g(x) + g^\prime (x) f(x)
Rearraging the equation above gives
f(x) g^\prime (x) = \left[f(x) g(x)\right]^\prime - f^\prime(x)g(x)
And integrating both sides with respect to x gives
\int f(x) g^\prime (x) \ dx = \int \left(\frac{d}{dx} (f(x) g(x)) - f^\prime(x)g(x)\right) \ dx
but certainly, \int \frac{d}{dx}(f(x)g(x)) \ dx = f(x)g(x), so this just reduces to
\int f(x)g^\prime (x) \ dx = f(x)g(x) - \int g(x) f^\prime (x) \ dx
which is what your teacher probably called the formula for integration by parts.
x^{2}dx=\frac{1}{3}d(2+x^{3}) so the integration is simple...
Daniel.
As others have said, you don't have to use integration by parts to solve this, but ...
Pick the term whose derivative will eventually go to zero (the soonest). In this case, it's x^2. First derivative is 2x. Second derivative is 2. Third derivative is 0.
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
