Integration involving complex exponentials
Jadaav
\int[( e^x + 4 )/ (4e^x + 1) ]^2
No substitutions have been given.
I've tried using the method of f' (x)/f (x). But it was in vain.
I haven't been able to do it. I don't really know where to start.
.. because clearly the numerator is not the derivative of the denominator.
Consider the substitution u = e^x.
Likes 1 person
Actually I was thinking about the substitution. But I have one question; an exponential function is not linear. So if I use substitution does it become a linear one ?
No. Your function will become a rational function. You will then be able to integrate it by following the method of partial fractions to separate it into a sum of known integrals.
Likes 1 person
OK thanks.
I'll start working on it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
