Integration problems: Intriguing Integrals
BioCore
\intx^3\sqrt{}a^2-x^2dx
I came this far with my solution:
a^5\sqrt{}sin^3\Theta cos^2\Thetad\Theta
a^5\sqrt{}sin^3\Theta-sin^5\Thetad\Theta
The answer given to me is:
-1/15(a^2 - x^2)^3/2 (2a^2 + 3x^2) + C
It seems that they used sine theta, and not cos theta. I have currently tried to do that but am not sure how I would get rid of the extra sin\Theta.
Thanks for the help.
\int x^3 \sqrt{a^2-x^2}dx
let x=acos\theta \Rightarrow dx=-asin\theta
\int x^3 \sqrt{a^2-x^2}dx \equiv \int (acos\theta)^3\sqrt{a^2-a^2cos^2\theta} \times -asin\theta d\theta
\int - a^4cos^3\theta \sqrt{a^2(1-cos^2\theta)} \times -asin\theta d\theta
-a^5 \int cos^3\theta sin^2\theta d\theta
recall that sin^2\theta +cos^2\theta=1
and substitute for sin^2\theta
I would assume that using your solution I would have the right answer. The only problem is that in the solutions my Professor gave us, he has an intermediate step before the final solution such as this:
a^5 \int sin^3\theta cos^2\theta d\theta
Also in explaining to us Trig Substitution he placed \sqrt{a^2 - x^2} as the bottom portion of the right triangle. Thus he stated that
x = asin\Theta
dx = acos\Theta
\sqrt{a^2 - x^2} = acos\theta
x = asin\Theta
dx = acos\Theta
Your teacher used x=sin\theta, I used x=cos\theta.
So in his triangle, sin\theta=\frac{x}{a} which would make the adjacent side,\sqrt{a^2-x^2}. At the end of that integral you would get terms involving cos\theta
In my substitution, the opposite side would be \sqrt{a^2-x^2} and at the end of my integral I would have terms involving sin\theta
So in theory it should all work out the same.
Ok following your steps:
-a^5 \int \sqrt{1 - sin^2\theta} (1 - sin^2\theta) (sin^2\theta)d\theta
= -a^5 \int (1 - sin^2\theta)^3/2 (sin^2\theta)d\theta
= -a^5 \int sin^3\theta - sin^6\theta d\theta
= -a^5 [1/4sin^4\theta + 1/7sin^7\theta ] +C
Now I know that I should substitute for the sine function, but is this so far correct?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
