Integrate f(t)f'(t) on [a,b] and Show 1/2[f''(b)-f''(a)]
  • Thread starter Thread starter trap
    Integration
The discussion centers on the integration of the function f(t) multiplied by its derivative f'(t) over the interval [a,b]. Participants clarify that the correct expression involves f²(t) rather than f''(t) in the solution. The hint provided suggests calculating the derivative of F(x) = f''(x) to aid in the proof. There is a consensus that the original question may have been copied incorrectly, leading to confusion. The conversation emphasizes the importance of accurate transcription in mathematical problems.
trap
Let f be a function such that f' is continuous on [a,b]. Show that
\int_a^{b} f(t)f’(t) dt = 1/2 [f''(b) - f''(a)]
Hint: Calculate the derivative of F(x) = f''(x).
Are you sure you copied the question correctly?
does it seem right now?
Shouldn't it be f² in the solution in stead of f" ?
i mean the integrand is f * df/dt * dt right? so you have f * df as integrand
marlon
1.DO NOT DOUBLE POST!
2.It's definitely
f^{2}(t)
The hint is good.I guess u needed us to tell u that u didn't copy the exercise properly. :-p
Daniel.
yes, you are right marlon, my bad all the way
