Integration (Related to Physics)
The discussion revolves around the confusion between differentiation and integration in the context of the equation for a straight line, y = mx + c. The user initially attempts to derive the slope (m) using the incorrect formula m = y/x, leading to a misunderstanding of differentiation. Clarifications highlight that the correct slope is defined as m = Δy/Δx and that the derivative of the equation yields m directly, not through the user's method. The user acknowledges the mix-up between integration and differentiation, indicating a need for further understanding of these concepts. Overall, the thread emphasizes the importance of correctly applying differentiation rules in physics-related equations.
_Mayday_
[SOLVED] Integration (Related to Physics)
This shouldn't take long :smile:
I have been given the general equation for a straight line which is:
y=mx+c
Now I know that to determine the gradient I can use:
m=\frac{y}{x}
Here is my question. Can I differentiate the initial equation given to get to m=\frac{y}{x}
If so, which I am sure you can, then I seem to have come across a problem, though I think it is a problem in my differentiation.
y=mx=c
\frac{dy}{dx}=mx^{-1}
m=\frac{y}{x^{-1}}
or
m=\frac{x}{y}
This does not agree with my initial statement. Either my differentiation is incorrect or I need to touch up on my laws of indices, and if neither of these maybe I am deluded and this can't be done anyway :-p
_Mayday_
(1) The slope is given by m = \Delta y / \Delta x, not m = y/x.
(2) The derivative (with respect to x) of mx + c is just m.
Just noticed the thread title is integration not differentiation. Thank you for your help.
