Integration using Hyperbolic Trig substitution
Krash
Evaluate:
\int\\{1}/{\sqrt{x^2-1}} dx between -3, -2
I know I'm supposed to use hyperbolic substitution in the question.
edit: cosh^2(t) - sinh^2(t) = 1
let x = -cosht, inside the integral let dx = sinh(t) dt
int ( sinht / sqrt(cosh^2t - 1) ) dt
now normally at this point i would use the trig identity cosh^2(t) + sinh^2(t) = 1 to eliminate the -1 in the root, however i can't work out how to sub into eliminate because I've had to use a negative cosht for x as the bounds of the integral are both negative.
I'm not great at this area of maths, I thought maybe if i substituted sinh(t) for x, I could possible rewrite -sinh(t) as sinh(-t) but I'm not sure if that's a fair solution or not.
your identity is incorrect, it's supposed to be cosh2t-sinh2t=1
cheers.
that still means i can't sub cosht for x but i can use sinh = x
then everything cancels and I am left with int dt
which is -sinh^-1(x)
which gives me:
(1 / (-sinh(-3))) - (1 / (-sinh(-2))) = -0.175898995
still not sure if this is technically accurate
this is the current solution I am working on:
dx = cosht dt
x = -sinht
therefore;
1/ sqrt(x^2 - 1 ) = cosht dt / sqrt( -sinh^2 t - 1 ) ----- (1)
using the trig id:
cosh^2 t - sinh^2 t = 1
-sinh^2 t = -cosh^2 t + 1 ----- (2)
(2) into (1)
int (cosht / sqrt(-cosh^2 t)) dt = int dt
int dt = t + c
t = 1/(-sinh x)
therefore the integral evaluated is:
so if you have \int dt =t +c
and x=cosh(t), doesn't it mean that t=cosh-1(x) ?
Sorry, x = -sinht, because the domain of the integral is negative.
i switched around the dx and x substitutions the second time around.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
