Intense Logarithmic Diferentiation Question
  • Thread starter Thread starter vexon
    Logarithmic
vexon
Hey guys, this is my first post and of course first question to ask of calculus
Alright well I had this test and we had this very difficult question that I could not solve, it was in the hardest section.
The question is as follows:
A projectile thrown over level ground, at an angle x to the ground, has a range R given by R = (v^2 / g)(sin2x), where v is the initial speed, in meters per second, and g = 9.8m/s^2. Determine the angle of proection x for which the range is maximum.
So I began to isolate for v^2 and then use log differentiation.
R(g) = v^2(sin2x)
v^2 = Rg / sin2x
R = ((v^2)(sin2x) / g)
ln R = ln v^2 + ln Sin2x - ln g
dR / dx = [(1 / v^2) + (1 / sin2x) - (1 / g)] (v^2(sinx) / g)
So I am pretty sure that derrivative is right but as of this i am clueless on what to do. Any help is really appreciated, even a guideline so I could figure out the rest myself. Thanks.
Welcome to the forums, vexon. You are making this problem much harder than it is. You don't need to take a log. And your differentiation is not correct. You have to use the chain rule. You just want to find dR/dx and set it equal to 0. What is the derivative of sin(2x)?
the derivative of sin2x is cos2x(2) = 2cos2x
but we were informed that log differentiation ln was to be used ?
But I'm still stuck. Could you help me further
oh i think i see it,
so since v and g are constants you don't differentiate them
therefore,
dR/dx = (v^2/g)(2cos2x)
and then
0 = v^2/g(2cos2x)
so in order to make the equation equal 0 the angle has to be 30 degrees is that correct ?
would this be the right answer?
The only thing that could be zero is cos(2x). And I don't think that happens at 30 degrees.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
