Intensity of polarized light that has passed through two polarizing sheets
A beam of polarized light with an initial intensity of 43.0 W/m² passes through two polarizing sheets, with the second sheet oriented at 90 degrees to the first. To find the angle θ of the first sheet, the relationship I1 = I0cos²(θ) is used to express the intensity after the first sheet, I1, and then related to the final intensity, Ifinal = I1cos²(90-θ). The discussion highlights the need to simplify trigonometric expressions, particularly using sin and cos identities, to solve for θ. Participants clarify the relationships between the intensities and angles involved in the problem. The conversation emphasizes the importance of understanding how the angles and intensities interact in the context of polarized light.
Kant Destroyer
A beam of polarized light of intensity 43.0 W/m2 is sent through a system of two polarizing
sheets. Relative to the polarization direction of that incident light, the polarizing directions of the sheets
are at angles θ for the first sheet and 90 degrees for the second sheet. If the intensity of the final, transmitted light is 8.6 W/m2, what is the value of θ?
I = I0cos2(θ)
I recognized that to solve the problem I had to work backwards to solve for θ.
I used the equation I = I0cos2(θ) and found that Ifinal = I1cos2(90-θ), where I1 is the intensity of the light after passing through the first polarizing sheet. Now I'm unsure where to head with this because I have two unknown variables, I1 and (90-θ). I am also lacking another equation to use a system of equations as far as I can tell.
What fraction of light makes it through the first polarising sheet?
The intensity of the light that is between the first and second polarizing sheets can be seen in my original post as I1.
Sure, but how does it relate mathematically to l0?
The relationship between I0 and I1 is: I1 = I0cos2(θ). Are you suggesting that I substitute this in for I1 in my equation and then solve for θ? I have tried this and I am not sure how to solve for theta in this instance.
How is theta involved? It hasn't reached the second filter yet.
As described in the question, theta is the angle of orientation of the first sheet relative to the polarization direction of the light entering the sheet. Per the relevant equation, this means that theta is used to find the intensity of the light after it has traveled through the first polarizing sheet.
You have I0 initially, I1 between the two sheets, I2 finally.
The last two are related by ##I_2 = I_1 \cos^2(\theta)##.
I'm asking how I1 relates to I0. Remember that the light between the two filters doesn't 'know' it's about to go through a second filter, so the angle theta can have nothing to do with this relationship. If it helps, mentally throw the second filter away and answer my question.
I think you misunderstand my original post because I failed to use another variable for the angle between the two polarizing sheets and instead used (90-θ). Theta is meant to represent the angle of orientation of the first polarizing sheet, and per the relevant equation it is used to find I1.
Sorry, dealing with too many threads at once. let me start again.
You have Ifinal = I1cos2(90-θ), I1 = I0cos2(θ) and the value of Ifinal / I0 . So your difficulty is in simplifying the trig, yes?
What trig formulae do you know which involve expressions like sin(θ)cos(θ)?
The only trig formulas I remember are sin2+cos2 = 1 and cos2(θ) = 1/2 + 1/2cos(2θ).
You need the one for expanding ##\sin(2\theta)##, and one for ##\cos(90-\theta)##. You don't know those?
I'm not even sure how sin(2θ) plays into the mix in this problem seeing as they are both cos2 functions, but no I do not know those. If I remember correctly the cos(90-θ) is actually just sin(θ) but I'm not sure about that.
Right. So making that substitution, write out the equation for Ifinal as a function of I0.
Ifinal/cos2(θ)sin2(θ) = I0
EDIT: Misread your response. Ifinal = I0cos2(θ)sin2(θ)
Right. You ought to know that ##\sin(2\theta) = 2\sin(\theta)\cos(\theta)##.
so cos2(θ)sin2(θ) = 1/4sin2(2θ) ?
If you mean (1/4)sin2(2θ) , yes. Now you can use the two trig equations you posted earlier to get rid of the remaining quadratic.
Thank you very much for taking the time to help me.
OK. Sorry about my earlier misdirection.
