Finding Internal Resistance of a Circuit
The discussion focuses on calculating the internal resistance of a circuit, specifically addressing confusion around measuring total resistance and the placement of a digital multimeter (DMM). The user initially assumed the total resistance (Rt) was 26.7 kohms by simply adding two resistors in series but found discrepancies with the book's answer. Suggestions were made to create a sketch of the circuit to clarify the DMM's placement and to consider the internal impedance of the meter. Additionally, it was recommended to calculate the circuit current and voltage across the resistors to understand how the effective resistance impacts the measurements. The importance of correctly positioning the DMM across the appropriate resistor was emphasized for accurate results.
Josh225
See image attached.
I am currently stuck on part b.
(Rt) (Rint) / Rt + (Rint)
I thought that Rt would be 26.7 kohms, but my answer is not matching up with the answer in the book. I am unsure why since the resistors are in series, so I figured I would just add the 2 values. Once I find that, I just plug in total resistance and internal resistance into the formula above. Then I would have to convert Mohms to kohms.
Does that sound right?
Thank you in advance
Can I suggest you make a sketch circuit showing the DMM modeled as an ideal DMM and an 11M resistor.
You don't say what Rt is?
You mention resistors in series but don't say which ones you are talking about.
Im not 100% sure by what you mean by making a sketch. I thought 26.7 kilohms would be the total resistance within the circuit (by adding the 2 resistors together). If not, how would you do so?
Here is my sketch, but am unsure it this is what you were suggesting.
Part (b) of the question asks you to measure V2 assuming an internal impedance of 11M in the meter. Your sketch shows the meter across the wrong resistor.
I would suggest you calculate the current in the circuit in the usual way, then calculate the voltage (theoretically) across R2. Once you have done that, measuring the voltage with the meter effectively places two resistors in parallel. So what do you think would happen to the circuit current if you change the effective resistance of R2? And if the current is different, what would happen to the voltage drop across R2, would it be the same as you calculated in part (a)?
Yes your sketch is exactly what I meant but as Numbskull said you have the meter across the wrong resistor.
