Interpretation of a memristor's hysterisis loop
The discussion centers around the interpretation of a memristor's hysteresis loop, focusing on the effects of frequency on the loop's shape and characteristics. Participants explore theoretical aspects, potential physical explanations, and specific observations related to the loop's behavior at varying voltage and current levels.
  • Some participants observe that as frequency increases, the area of the hysteresis loop decreases, and the graph tilts more towards the x-axis.
  • There is a suggestion that at very high frequencies, the memristor behaves like a constant value resistance, potentially at its minimum memristance.
  • Participants express uncertainty regarding the reasons for the observed tilt in the hysteresis loop and the slight deformity at higher voltage-current values.
  • One participant proposes that the skin effect may explain the tilt observed in the hysteresis loop.
  • Another participant references a paper discussing the tunneling effect at higher voltages as a possible explanation for the deformity in the memristor's I-V curve.
  • There is a mention of the linear-drift model for mobile dopants, which some participants believe does not account for the tunneling effect, potentially leading to the observed deformity.
Participants express various hypotheses and potential explanations for the observations, but there is no consensus on the reasons behind the tilt and deformity in the hysteresis loop. Multiple competing views remain regarding the underlying physics.
Participants note that the discussion relies on specific models and assumptions, such as the piecewise linear model and the linear-drift model, which may not fully encompass all physical phenomena involved.
madaari
Hi forums,
Following is the hysteresis loop of a standard memristor:
Please note that, the red one is for lowest frequency and black for highest frequency.
From the graph, one can take the following observations:
1> As frequency increases, area of graph decreases
2> With increase in frequency, graph tends to tilt more towards x axis
3> Slight deformity of the red curve at higher VI values.
I tried interpreting these observations, keeping in mind memristors Piecewise linear model(Is that a correct assumption?).
If second observation is correct:- Memristance decreases with increase in frequency and at frequency tending to infinity, it acts like a constant value resistance whose value should be Minimum possible value of memristance. Right?
Also, I need a bit explanation for observation number 3(about deformity). I'm unable to figure out it's reason.
Thanks,
[moderator edited out the OP's name and cross posting info.]
Yup, I had a look at it. I'm mostly comfortable with the physics, just had few questions about shape of hysteresis loop, the ones that i mentioned in my earlier post i couldn't correlate that to theory. Mainly, these two:
What's the reason of this tilt in 2? and deformity in 3?
Ok, thanks. Skin effect could be a reason, i'll dig deeper into it.
But it's only skin deep :smile:
Ok, got one more strong argument for (3) observation i.e slight deformity at higher i-v values. In this paper:
M. D. Pickett, D. B. Strukov, J. L. Borghetti, J. J. Yang, G. S. Snider, D. R. Stewart, and R. S. Williams, “Switching Dynamics in Titanium Dioxide Memristive Devices,” J. Appl. Phys., vol. 106, p. 074508, 2009.
They explained the dominance of tunneling effect at higher voltages, which could lead to the observed slight deformity in memristor's i-v curve.
I guess that these loops are calculated on base of the "memristor" model presented by Strukov et al. in their paper "The missing memristor found". If this is the case, there are no more physics in than a simple linear-drift model for mobile dopants.
  • · Replies 22 ·
  • · Replies 21 ·
