Interval increasing/decreasing
  • Thread starter Thread starter jwxie
    Interval
jwxie
ln(3x+5) Determine intervals on which the function is increasing, decreasing, concave up, and concave down.
So I did f '(x) = 3/3x+5
this gives me 3x+5 = 0, and I get x = -5/3 (point where the y is zero)
Now, I did f '' (x), and got -3/(3x+5)^2
this gives me (3x+5)(3x+5), i did a number line test, with the only value -5/3, and anything below -5/3 is negative, and before -5/3 is positive
this gives me that, the function is decreasing after -5/3, and increasing after -5/3.
Now what about the concavity?
No, f'(x) is never zero.
You're not taking into account the domain of the original function, f(x) = ln(3x + 5). This function is defined only for x such that 3x + 5 > 0. The first and second derivatives have the same domain.
Look at the sign of f''(x), which by the way is not equal to 3/(3x + 5)^2. Keep in mind what the domain is.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
