Intro EE - Voltage Divider Design circuit
The discussion focuses on designing a voltage divider circuit using the equations V_out/V_in = R_2/(R_1 + R_2) and R_thevenin (R_th) = R_2*R_1/(R_1+R_2). The conditions specified are 10,000 ≤ R_th ≤ 30,000, leading to the conclusion that R_1 must be in the range of 50kΩ to 150kΩ. The viable resistor values for R_1 identified are 56kΩ, 68kΩ, 82kΩ, 100kΩ, 120kΩ, and 150kΩ. The calculated R_2 values corresponding to R_1 are 14kΩ, 17kΩ, and 20kΩ, which were adjusted to meet a 10% tolerance condition.
  • Understanding of voltage divider circuits
  • Familiarity with Thevenin's theorem
  • Knowledge of resistor value series (E12 series)
  • Basic algebra for manipulating equations
  • Study the application of Thevenin's theorem in circuit analysis
  • Learn about resistor value series and their applications in circuit design
  • Explore voltage divider circuit applications in real-world scenarios
  • Investigate tolerance calculations for resistors in circuit design
Electrical engineers, circuit designers, and students studying electronics who are interested in voltage divider design and Thevenin's theorem applications.
krtica
The link is an image with the question and circuit representation:
http://i49.tinypic.com/2mmwg8l.png
Here are the equations I used:
V_out/V_in = R_2/(R_1 + R_2) {using the node method}
And given the conditions =>
10 < R_th < 30
Manipulating this inequality I found that 50 < R_1 < 150, which left me with three possible values for R_1 (56, 68, 82).
Using the first equation, I put in the numbers, which gave me 0.2=R_2/(R_2+56) and solved for R_2 with every value I put in for R_1 (56, 68, 82).
R_2 values were 14, 17, and 20, respectively, which came to equate to 15, 18, and 22 when compared to the original set of resistors and the 10% condition.
I tried putting in the values of these resistors I used, because all gave me the right ratio of voltages, but they're incorrect.
Pardon how nuanced I may seem, it's been too long since I've done any physics..
I think you are on the right track.
10 < R_th < 30
This should be, 10,000 ≤ R_th ≤ 30,000
Aren't you missing some candidates here?
R₁ ∈ {56k,68k,82k,100k,120k,150k}
Wouldn't it just be the three since your given all the resistances available in the set E12?
120kΩ = 12 x 104
Right! Thanks.
  • · Replies 29 ·
  • · Replies 23 ·
  • · Replies 16 ·
