Intro physics question involving magnitudes and vectors
The problem involves analyzing forces in a physics context, specifically focusing on vector magnitudes and their components. The scenario describes a person hanging from a chinning bar, with forces exerted by their arms at right angles to each other, supporting their weight of 620 N.
  • Exploratory, Assumption checking
  • The original poster attempts to sketch the force vectors and calculate their magnitudes using trigonometric relationships, specifically referencing a right triangle formed by the forces. They express uncertainty about their calculations and seek feedback on their approach.
Some participants provide affirmations regarding the original poster's calculations, indicating that the approach may be valid. However, there is no explicit consensus or resolution on the correctness of the calculations, and the discussion appears to be ongoing.
Participants note the importance of adhering to posting guidelines, suggesting that there may be specific requirements for how to present the problem or engage in the discussion.
Kevin Bertham
You’re hanging from a chinning bar, with your ;arms at right angles to each other. The magnitudes of the forces exerted by both your arms are the same, and together they exert just enough upward force to support your weight, 620 N. (a) Sketch the two force vectors for your arms, along with their
resultant, and (b) use components to find the magnitude of each of the two “arm” force vectors.
So i drew the triangles out with 310 across the x-axis and 620 down.
The 90 degree angle as well as the two 45`s . I went to find the H which is cos 45= O/H , multiply by H on both sides so its H*cos45= 310 divide both by cos 45 which leaves you with H=310/cos45 which leaves with 438 N as the resultant. That is what i did anyway I don't think i am correct but if someone could give this a peak.
Want a second opinion ? You're still correct !
lol they said i needed to follow the posting guidelines
Still true: use the template (you should also READ the guidelines ;-) )
  • · Replies 21 ·
