Introductory circuit analysis - thevenin circuits
The discussion revolves around solving a circuit analysis problem involving Thevenin circuits, specifically focusing on calculating the Thevenin equivalent voltage (Eth) and resistance (Rth) in a circuit with multiple voltage sources and resistors. Participants explore different methods and approaches to arrive at the solution.
  • Homework-related
  • One participant describes their attempt to calculate Eth using the superposition principle but encounters difficulties, particularly in assuming the voltage across a specific resistor is equivalent to Eth.
  • Another participant suggests converting voltage sources and resistors into current sources and resistors in parallel as a potentially simpler method to solve the problem.
  • A later reply clarifies that Eth is not simply the voltage across the 6.8 kOhm resistor but includes additional voltage from another source.
  • One participant expresses uncertainty about their calculations, noting a discrepancy between their result and the expected value, and seeks confirmation on their approach.
  • Another participant provides mesh analysis equations to derive Eth, leading to a calculated value that slightly differs from the expected answer.
Participants do not reach a consensus on the correct approach to calculate Eth, with multiple methods proposed and some disagreement on the assumptions made regarding the circuit components.
There are unresolved assumptions regarding the circuit configuration and the roles of various components, which may affect the calculations. Some participants mention specific resistor values and configurations that are not fully detailed in the discussion.
Students and individuals studying circuit analysis, particularly those interested in Thevenin's theorem and its applications in complex circuits.
Mohdoo
Thevenin stuff, right?
So, I tried to re-write everything and make it a bit easier to understand:
I ended up getting Rth completely fine and everything, but I can't seem to get Eth.
So from there, I figured that I simply do like other problems that have 2 voltage sources. Simply act as if all the other sources are pieces of wire while leaving one at a time actually there, getting the voltage, etc.
The only thing about this is, I assumed that the voltage of AB is the same as the voltage of the6.8K resistor. When I looked over other examples, all of which only had 2 voltage sources, the voltage of AB was simply the voltage of a resistor in the same place that the 6.8K resistor was. But the thing is, in those examples, there were only 2...Not sure if that messes things up =(
So then because E1 had a positive polarity, E2 had a negative, and E3 had a positive, I added E1 and E2, then subtracted E2. When I did this, I simply got the completely wrong answer. Rth was fine, but Eth is just plain completely wrong. The book says that Eth should be 9.74V. I got like 12 something =(
Help? =(
Mohdoo said:
So from there, I figured that I simply do like other problems that have 2 voltage sources. Simply act as if all the other sources are pieces of wire while leaving one at a time actually there, getting the voltage, etc.Help? =(
You mean you are using the superposition principle?
I am not sure what is AB .. you haven't labeled it anywhere.
However, one simpler approach I can suggest is to convert each voltage and resistor line to a current source and resistor in parallel. Add up all the currents and add up all the resistors also in ll.. (sorry, missed the 3.3kohm, can do this to the first two wires and then add 3.3.. and do the last wire). I was able to come with 9.76 number (few rounding problems) under 30 seconds through this approach however your approach requires some paper work..
My apologies. I meant to label the two ends of "Rl" as A and B. I was told that using superposition, I am supposed to do that, and find Eth as the voltage between A and B.
So what you did was simply make the first two wires current with resistors in ll? I'll give it a shot! I don't suppose you could post some of the formulas you used?
Thanks again!
This is what I used:
Your assumption is wrong that E_thevinan is equivalent to the voltage across 6.8 kOhms, it is equal tp the voltage across 6.8 kOhms + 6 V.
Ok, I think I got it!
I think that my first 2 voltages were right. That is to say, for E1, and E2. I think my problem came from E3. If I am incorrect, please correct me.
So what I changed was, well, I'll simply attach a picture of how I changed E3 and then added all the voltages together for Eth:
The only thing is that I got about 9.84...Not 9.74. Did I just get lucky by getting close? Or am I almost sort of right?
Once again, I really appreciate your help. You've been a huge help to me.
Eth is measured from voltage drop of the 6.8kohm resistor and the 6v source so discard the 1.2kohm resistor and RL
now your circuit has only two meshes instead of three so by kvl the equations below were derived. I1 mesh current on the left and I2 mesh current on the right
1. 7.8kI1 - 5.6kI2 = 34
2. -5.6kI1 + 15.7kI2 = -18
solving these equations will give I2 = 0.549mA
thus Eth = 6.8k(0.549m) + 6 = 3.73 + 6 = 9.73v
Thanks for the replies everyone! I get it :D
  • · Replies 42 ·
