Invention in need of professional help.
The discussion focuses on developing an invention that uses a rotary switch to activate an LED light based on weight measurements. A mechanical solution involving a spring balance is suggested, where the weight stretches a spring to close a switch. Participants discuss how varying the switch's position can change the weight required to activate it, and alternative methods like using a pulley system are proposed. Seeking assistance from an electrical engineer is recommended to ensure proper design and functionality. Overall, professional guidance is emphasized as crucial for successfully bringing the invention to fruition.
kaminar
I have an idea for an invention and I am trying to work out the circuitry. I need some type of rotary switch or another devise that will be user adjustable and assigned to a given weight, then when that weight is achieved on a scale it turns on a basic LED light. I know its a really loaded question but any advise in basic terms would be much appreciated.
Thanks in advance!
If you wanted to do it with a mechanical device, probably a variation on a spring balance would be used.
The weight stretches a spring and this could then make a contact with a switch.
Varying the position of the switch would vary the weight needed to cause switching.
Cheaper bathroom scales still use this system but newer, more expensive ones use load cells.
That's great vk, I appreciate the response. I have sat for the last couple hours with a spring scale and have a pretty decent understanding of the mechanics. I am still struggling with what you mean by Varying the position of the switch would vary the weight needed to cause switching. What does that look like? What kind of rotary switch could I use? What would the mechanics look like on the inside?
Thanks to everyone for their help.
If you have a pulley which rotates when pulled by a rope, but is spring loaded to return to its original position, you could mount a piece of metal on the rim of the pulley which will operate a switch when the pulley rotates far enough.
So, a sufficient force on the rope will cause the switch to be operated and turn on a light.
You could have the switch on a platform which could be rotated so that different positions of the pulley will operate the switch.
As part of your invention, you would have to adapt this principle to suit the design.
I would first like to commend you for your innovative thinking and for seeking professional help in developing your invention. In order to achieve your desired outcome, I would recommend seeking the expertise of an electrical engineer or a professional in the field of circuitry. They can help you design and implement a rotary switch or other device that can accurately measure weight and trigger the LED light. It is important to have a clear understanding of the specifications and requirements for your invention in order to create an effective and functional circuit. Additionally, it may be helpful to conduct research and explore similar existing products to gain a better understanding of the technology and components needed for your invention. I wish you the best of luck in developing your invention and I am confident that with the help of a professional, you will be able to bring your idea to life.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
