Linear Combination Mapping: Is the Invertible Matrix Theorem True or False?
  • Thread starter Thread starter henry3369
    Matrix Theorem
henry3369
True or False:
If the linear combination x -> Ax maps Rn into Rn, then the row reduced echelon form of A is I.
I don't understand why this is False. My book says it is false because it is only true if it maps Rn ONTO Rn instead of Rn INTO Rn. What difference does the word into make?
henry3369 said:
True or False:
Consider the transformation whose matrix looks like this:
$$A =
\begin{bmatrix}1 & 0 & 0 & \dots & 0 \\
0 & 0 & 0 & \dots & 0 \\
\vdots \\
\end{bmatrix}$$
This transformation maps a vector x to its projection on the ##x_1## axis, a map from Rn into Rn (but not onto Rn). Does it seem likely to you that this matrix will row reduce to the identity matrix?
$$A =
\vdots \\
\end{bmatrix}$$
So if it maps onto Rn does that mean that it maps x into every position in Rn?
Also can you clarify why these two statements are equivalent in the Invertible Matrix Theorem::
1. The equation Ax = b has at least one solution for each b in Rn
2. The linear transformation x -> Ax is one-to-one.
What is throwing me off is the word least in statement 1. Shouldn't it have exactly one solution for every b in order for the transformation to be one-to-one?
Yes, I'm bothered by it as well. It's technically correct, but misleading, as it seems to imply that for some b there might two input x values. That can't happen if the transformation is one-to-one, though.
To me, it's sort of like saying 3 + 4 is at least 7.
Yes, this is rank-nullity, together with the fact that a linear map is injective iff it has a trivial kernel.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
