Investigating the Mass of Ice Melted by a 2.65g Aluminum Bullet
A 2.65g aluminum bullet fired into ice at 209 m/s generates kinetic energy that contributes to melting the ice. The initial kinetic energy is calculated using the formula E_k = 0.5 * m * v^2, leading to a change in energy when the bullet embeds itself in the ice. The discussion highlights the need to account for this kinetic energy conversion into heat to determine the amount of ice melted. The initial calculations for heat energy and mass of ice melted were incorrect due to not considering the bullet's velocity. The correct approach involves calculating the kinetic energy and then using it to find the mass of ice melted.
Boozehound
A 2.65g aluminum bullet at 31.4°C is fired at a speed of 209 m/s into a large block of ice at 0°C, in which it embeds itself. What quantity of ice melts?
Q=(9.00E2)(.00265)(31.4)=74.889J
74.889J=m(33.5E4)=2.23E-4kg
so i get a final answer of 2.23E-4kg but its wrong. i think I am either missing a step because I am not using the velocity of the bullet, or I am plugging wrong numbers in. any help is appreciated.
I think you need to consider the change in kinetic energy, which i assume is all converted to heat energy, thus, increasing the temperature of the bullet.
what formula would i use for that? i looked in my book and i couldn't come up with a formula...
Well kinetic energy is given by E_k = \frac{{mv^2 }}{2}.
You can work out the initial kinetic energy by simply using m=0.00265, v=209, and then find a final kinetic energy, using the same mass, but v=0, since it has stopped in the ice. Then find the change in energy from those.
alright i got it thank you very much!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
