Comparing Thermometer Readings of Different Metal Cubes in Boiling Water
  • Thread starter reycristobal
  • Tags
    Iron Volume
In summary, the smaller cube of iron would have a higher temperature than the larger cube after being heated for the same amount of time. In the second problem, the cube with the smaller volume would reach its final temperature first due to its lower mass. The final temperature for all cubes would eventually be the same as the boiling water, but the smaller cube of iron would reach this temperature first.
reycristobal
A physics student has two cubes of iron. One cube has three times the volume of the other. The cubes are heated over identical flames for the same amount of time. The cubes are then removed and the temperature of each cube is recorded immediately.
How will the thermometer readings compare?
Q=mc∆t
My initial thought was that a smaller volume meant a smaller mass and that the smaller mass would have a lower temperature than that of the bigger volume.
A physics student has three cubes of metal: a 100 g cube of iron, a 300 g cube of iron, and a 100 g cube of aluminum. The student puts the cubes into a beaker of boiling water. The cubes remain in boiling water until each cube is as hot as it is going to get. The cubes are then removed and the temperature of each cube is immediately recorded.
Which cube reached its final temperature most quickly?
Discuss how the answers to this exercise differ from the answers to the preceding exercise.
Specific Heat of Aluminum: 0.215 cal/g/degree Celsius
Specific Heat of Iron: 0.1 cal/g/degree Celsius
Specific Heat of Water: 1 cal/g/degree Celsius
Q=Q=mc∆t
1. The 100 g iron cube would have the highest temperature because of its small mass. The 100 g aluminum cube would have the lowest temperature because of its high specific heat.
2. The 100 g iron cube would reach its final temperature first.
3. ?
1.) For one -- I'm going to make the assumption that the iron cubes are initially at the same temperature.
Now we can relate volume = mass / density. Since density is an intrinsic property of a material it's independent of how much of the substance we have it will always be constant. This means that a larger volume would indeed have larger mass given to samples of the same substance.
Now you're asked about the final temperature of the two materials while giving each sample the same amount of heat, the heat capacity has to be the same because it's also intrinsic, and the initial temperature is the same.
What can we say about the final temperature? Rewrite Q = mC∆t in terms of final temperature and the answer will really stick out.
2.) You might want to actually compute the ratios to make sure you're correct.
If you keep tip of a needle in a flame, it becomes red hot quickly. Now if you keep tip of a large nail of the same material as that of needle, it takes longer time to become red hot.
Similarly what happens in the above problem?
2.) Looks right, you might want to actually compute the ratios to make sure you're correct though.
Can you assist me with the 2nd part, I don't know what ratios to compute.
The cube with the less volume (less mass) would heat up first.
For the second question regarding the cubes in boiling water, wouldn't they all eventually reach 100 degrees Celsius?
They all get to temperature, so they should all read the same immediately after removing from the 100° bath.
Related to Comparing Thermometer Readings of Different Metal Cubes in Boiling Water
1. What are iron cubes?
Iron cubes are three-dimensional solid objects made of pure iron. They have six equal square faces and the same length, width, and height. Iron cubes are often used in scientific experiments and as building blocks for larger structures.
2. How is the volume of an iron cube calculated?
The volume of an iron cube is calculated by multiplying the length, width, and height of the cube. This can be represented by the formula V = l x w x h, where V is the volume, l is the length, w is the width, and h is the height.
3. What is the density of an iron cube?
The density of an iron cube is the mass of the cube divided by its volume. The average density of iron is 7.8 grams per cubic centimeter. Therefore, the density of an iron cube will vary depending on its size and shape.
4. How does the volume of an iron cube change with temperature?
The volume of an iron cube will expand or contract with changes in temperature. This is due to the thermal expansion properties of iron. As temperature increases, the molecules in the iron cube vibrate faster and take up more space, causing the volume to increase. As temperature decreases, the molecules slow down and the volume of the iron cube decreases.
5. Can the volume of an iron cube be measured accurately?
Yes, the volume of an iron cube can be measured accurately using various methods such as displacement, geometric measurements, or water displacement. It is important to use precise and calibrated instruments to ensure accurate measurements.
