Irreversible process Entropie-Change/cylinder
For irreversible processes, the entropy change is represented by the inequality ds > dQ/T, indicating that entropy increases. However, when calculating the entropy change of a cylinder connected to a heat reservoir, the equation ds = dQ/T can be used if the heat transfer occurs reversibly. The distinction lies in whether the process is reversible; the second equation applies to the heat reservoir, which maintains a constant temperature. The key factor is that the system's behavior determines the applicability of the equality versus the inequality. Understanding these principles is essential for accurate thermodynamic calculations.
Abigale
Hi,
I have read that for an irreversible process the equation for the entropy is: $$ds>\frac{dQ}{T}$$
But if I regard a cylinder connected to a heatreservoir and want to callculate the entropychange of this cylinder, why can I use the equation: $$ds=\frac{dQ}{T}$$?
THX
Your inequality applies to the closed system that you are applying the process to. Your second equation is not the entropy change for the material in the cylinder unless the process is reversible, irrespective of the heat reservoir. If you regard the heat reservoir as a system, then the second equation describes its change of entropy, since its temperature is constant and (virtually) uniform, and the heat addition takes place reversibly. The key to inequality vs equality is if the system under consideration is undergoing a reversible change.
