Is a binary distillation column limited by Carnot?
A distillation column operates similarly to a heat engine, featuring hot and cold sides that reject heat. It is suggested that the maximum efficiency of a distillation column could be determined using Carnot efficiency principles, given its energy dynamics. Despite this theoretical framework, real-world heat engines, including distillation columns, rarely achieve efficiencies close to the Carnot limit. The discussion emphasizes the relevance of Carnot efficiency in evaluating the performance of distillation processes. Understanding these limitations is crucial for optimizing distillation column design and operation.
ejnovek
Hi Physics Forums,
I'm wondering if a distillation column is limited by the carnot efficiency and, if so, how this limitation can be used to determine the maximum efficiency of a distillation column with particular hot and cold side temperatures.
A distillation column has a hot and cold side and rejects heat. Additionally, the energy of demixing could be classified as 'work.' In this way it resembles a heat engine.
Science news on Phys.org
All heat engines are restricted to carnot efficiency.
The theorem is used the same way for all heat engines.
However, almost no heat engines have efficiencies close to the carnot efficiency.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
