Is Delta Enthalpy Zero for an Isothermal Gas Expansion Process?
  • Thread starter Thread starter sachin123
    Delta Zero
In an isothermal process involving gas expansion, the relationship between delta enthalpy (delta H) and other thermodynamic variables is clarified. While delta H is expressed as delta U plus the work done, it is important to note that delta U is zero in this scenario. The work done is calculated as nC ln(V2/V1), leading to the conclusion that delta H is not zero. However, the correct formulation states that delta H equals delta U plus delta(PV). For an ideal gas, delta(PV) can be expressed as R delta(nT), which equals zero if the number of gas molecules (n) and temperature (T) remain constant. Thus, under these conditions, delta H is indeed zero, contradicting initial assumptions.
sachin123
Is delta enthalpy zero for...
Is delta H, for an isothermal process in which a gas expands?
delta H=delta U+work done,correct?
delta U is 0,but work done = nCln(V2/V1).
So,delta H is not equal to 0.But my book says so.
Chemistry news on Phys.org
No. deltaH = deltaU + delta(PV). Work done is p delta(V) (under conditions of constant pressure).
For an ideal gas delta(PV) = R delta(nT). As long as the number of gas molecules in the system (n) and the temperature (T) remain constant, delta(PV) = 0.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
