Is Delta Enthalpy Zero in Isothermal Expansion with Heat Absorption?
  • Thread starter sachin123
  • Tags
    Delta Zero
In summary, delta enthalpy is typically zero for a physical change, but it can also be zero for a chemical change if the reaction is carried out under constant pressure and no work is done. It can also be negative in exothermic reactions and is equal to the heat of reaction under constant pressure. Delta enthalpy is affected by the temperature of the reaction and can be calculated by subtracting the enthalpy of the reactants from the enthalpy of the products or by measuring the heat released or absorbed during a reaction.
sachin123
121
Is delta enthalpy zero for...
1 mol of ideal gas expands isothermally at 274 K ,from pressure 1.1 atm to 1 atm.It absorbs 8.314 J of heat.Find free energy change.
dG=dH-T dS...1
dS=dq/T
dH=dU+Work done
Work done=nRTln(P1/P2)...2
dU=0
dH=Work done
dH=whatever u get in 2
dG=whatever u get by substituing values in 1.
But my book says dH=0 because the process is adiabatic.Isn't that wrong?
I would like to clarify the statement made in the forum post. The delta enthalpy is not necessarily zero for an ideal gas expanding isothermally. It depends on the conditions and assumptions of the system.
In this case, the process is described as isothermal, meaning that the temperature remains constant throughout the expansion. However, the gas is also said to absorb heat, which suggests that the process is not truly isothermal and there is some heat transfer involved.
Furthermore, the statement that dH=0 because the process is adiabatic is incorrect. Adiabatic means that there is no heat transfer, but it does not necessarily mean that there is no change in enthalpy. Enthalpy is a state function and can change even in adiabatic processes.
To accurately determine the free energy change, the conditions and assumptions of the system must be clearly stated and taken into account. This includes the type of process (isothermal, adiabatic, etc.), the heat transfer, and any work done. Once these factors are determined, the appropriate equations can be used to calculate the free energy change.
I would say that the book is incorrect. The process described is not adiabatic, as heat is being absorbed. Adiabatic processes do not involve the transfer of heat. Therefore, the change in enthalpy, or heat content, is not zero. The correct approach would be to use the equation dG=dH-TdS, as you have done, and substitute the values given to find the free energy change. This will give a more accurate result.
Related to Is Delta Enthalpy Zero in Isothermal Expansion with Heat Absorption?
1. Is delta enthalpy zero for a physical or chemical change?
Delta enthalpy is typically zero for a physical change, such as a change in state (e.g. solid to liquid) at constant pressure. However, it can also be zero for a chemical change if the reaction is carried out under constant pressure and no work is done.
2. Can delta enthalpy ever be negative?
Yes, delta enthalpy can be negative if the reaction releases heat or if the reactants have a higher enthalpy than the products. This is known as an exothermic reaction.
3. How is delta enthalpy related to the heat of reaction?
Delta enthalpy is equal to the heat of reaction under constant pressure. This means that the change in enthalpy of a reaction is equal to the amount of heat released or absorbed during the reaction.
4. Is delta enthalpy affected by the temperature of the reaction?
Yes, delta enthalpy is affected by the temperature of the reaction. As the temperature increases, the enthalpy of the products will also increase, resulting in a larger delta enthalpy value.
5. How is delta enthalpy calculated?
Delta enthalpy can be calculated by subtracting the enthalpy of the reactants from the enthalpy of the products. This value can also be determined experimentally by measuring the heat released or absorbed during a reaction.
  • Materials and Chemical Engineering
