Programs Is it possible to do masters in nuclear engineering with a physics degree
Pursuing a master's in nuclear engineering with a physics degree is feasible, as many individuals have successfully made this transition. It's essential to review the specific admission requirements of the nuclear engineering programs of interest. If the eligibility criteria are unclear, contacting the schools directly for clarification is recommended. Prospective students may need to complete additional undergraduate courses in areas like fluids and heat transfer, which are more application-focused than typical physics coursework. Experiences shared in the discussion primarily reflect the context of the US and Canada, indicating that requirements may vary in other countries.
boringelectron
It seems that lots of people do, so sure.
You might want to check out the admission requirements in nuclear engineering MSc programs that you're interested in. If it's not clear on the website whether your degree would be accepted, you can always contact the school directly.
Likes boringelectron
I did, and I know a lot of other people who did, as well. But that was a long time ago, so Choppy's advice to check with the schools is a very good idea.
Thank you so much
I will check out for more information.
I would expect that you will likely find yourself needing to take some undergraduate fluids and heat transfer that were more application oriented than what you might have encountered in physics.
Note that the people above speak from experience in the US and Canada. In other countries, the details may be different.
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
